While running, does the engine seem bogged down like the pump is working/trying to put out presure? I had that problem on my 300...as previously mentioned, there is a small screen inside the pressure regulator block, if this is plugged or collapsed on itselt (like mine did) it will cause your problem. If this is the case, the pump will also get very hot very quickly while tractor is running.
Was the system full of fluid before you got the tractor? Either way it could also be air locked (also previously mentioned). My 400 did that once to me while changing hoses on the loader. I took the breather tube off the top of the reservior and stuck my rubber tipped air gun in the hole. With the tractor running, give it a little shot of air and the pressure should push the fluid through the lines and the air out.
While you are checking these things, it would be a good idea to throw a wrench on your 3 valves and make sure they are all set to either single or double acting. There are roll pins on the top that is supposed to point to which way they are set but those pins can get bent or twisted...if one of your valves is stuck in the middle it would also cause your problem. That also happened to me on the 300 I had.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
