Thanks, and I should have mentioned it's a mag ignition.
Do you know if any re-wiring will be required going from a cutout to a regulator?
I'm not positive that it actually was a cut-out relay, as it was bigger than any cut-out I have ever saw, but different from any regulator I ever saw.. (not saying I saw a lot of em, but..) I just planned to ask the fella redoing the generator, as he is very knowledgeable.
The best I can describe, it was around 2" square "saddle mount" (typical of the regulators I am familiar with) On one side it had 2 wires, which IIRC hooked each post of the generator to each post on that side of regulator, Opposite side had 1 wire hooked up, and without tracing it, appeared to run back to previously mentioned box.
Sound like it would be wired correctly for a cut-out, or a regulator, or would it be the same either way?
thanks,
Brad
PS.. I may end up going negative ground.. probably be easiest after thinking on it.. I pay attention to hooking up booster cables and chargers.. But sometimes my dad does not..
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
