Larry wants to know how to start his "new-to-him" LP tractor.
This begs the question: Have you seen it running? If so, turn on the vapor valve, move the throttle half way, turn the ignition key, and probably play with the choke. Not much different than a gasoline engine. If you are going to work it hard, turn on the liquid valve.
If the ignition is OK and it won't start, you are either out of fuel or the regulator is faulty. There is a small likelihood that the shutdown diaphragm in the carb is faulty but that is your lowest priority troubleshooting step. The diaphragm shuts down the fuel flow when there is no intake manifold vacuum.
Check to see if anyone has been wrenching on the regulator. If so, someone else (or the IH manual) will need to assist you.
I have a W-400LP but have only started it half a dozen times and refueled it once. I had to replace the regulator after not running the tractor for many years. The internals were heavily corroded.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
