Posted by pete 23 on March 03, 2011 at 10:32:55 from (173.87.146.142):
In Reply to: injector pump????? posted by brett munsey on March 02, 2011 at 09:50:43:
Seeing air and foam in glass bowl means you have a restriction between bowl and tank and it is drawing air in around gasket of bowl. It some times happens that a baffle in fuel tank comes loose and lays over outlet. In that case I put a slot in fitting so it cannot shut off flow. This happens in the 450 diesels, don't know if your tank has baffles or not. Even a plugged fuel cap can cause this problem also unless tank has seperate vent which of course can become plugged also.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
