Re: Farmall 460lp questions
Posted by Owen Aaland on February 27, 2011 at 16:03:24 from (65.174.247.39):
In Reply to: Farmall 460lp questions posted by Jeff Oliver on February 27, 2011 at 11:56:49:
Even if the valve are working and shutting off completely the engine will run for several minutes before it runs out of fuel. With the liquid line filled between the valve and regulator there may be enough fuel to idle for 15 minutes. Another thing about propane is that it behaves a little different than gasoline in that it will migrate based on temperature/pressure rather than just gravity. Even with just the vapor line open, if the tank is warmer than the vapor line, fuel in the line will condense until both the liquid and the vapor line are filled with liquid.
If there is a problem with the valves it could be the cause of your sputter and lose of power. Valves not opening enough can cause lean conditions. Also if you do not have enough coolant flow through the regulator/converter assembly it will cause flooding as liquid fuel enters the mixer. A restricted valve or line will cause a temperature drop at the point of restriction. Any time the pressure is reduced on the propane it will absorb heat. That is why the regulator need warm coolant flowing through it.
With propane I would not go any heat range warmer than a Champion D15Y spark plug. Propane normally can use a plug one to two heat ranges colder than the same engine running on gasoline. It also takes more voltage to fire the spark plug with a propane fuel mix versus a gasoline fuel mixture. I would gap them in the .017 - .020 inch range.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
