Posted by Tom in Iowa City on February 27, 2011 at 06:01:22 from (173.30.220.194):
I have learned quite a bit. Problem, again, is to try to get a tighter fit between the spline shaft of the transmission and the transmission joint (hub) due to excessive wear.
Here is what I have learned: 1. Probably no problem to run the tractor AS IS and except the wear. I will be running it quite little, although I want to take it to a show once in a while, run it a little around my shop from time to time.
2. To fix it: a. Welding, milling and re hardening. Concerns with welding: A. getting a hard enough welding rod. B. softening of the shaft due to heat incurred with welding. C. need or no need to re harden the shaft.
A local shop estimated it would cost about 600 dollars to do this. A little rich for my blood.
A neighbor offered to TIG weld one spline at a time and then I use my sweat equity to grind to fit. Then we do a spline opposite to that one, again I regrind.
Question: would this weld be hard enough to be adequate? (It would be normal TIG weld, if there is a normal hardness with TIG weld.)
Question: would this soften the shaft enough that I would have to reharden it?
Could I take the welded, ground rod to a shop to have them re harden it? I understand re hardening might entail heating to say 1500 and then quenching and then heating to say 750 and quenching to draw it.
I have had a neighbor 30 miles away offer to help also.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
