Posted by Owen Aaland on February 24, 2011 at 12:53:49 from (65.174.247.39):
In Reply to: 1066 hydraulics posted by Michael Sheik on February 24, 2011 at 05:46:01:
The MCV hydraulics are separate from the hitch. The failure to lift properly is most likely caused by a weak pump. As pressures go up the pump flow decreases.
The problem with the baler not maintaining pressure is either in the cylinder(s) on the baler or a auxiliary valve leaking past the spool lands. There is no repair for that valved problem other than replacement of the entire valve. Many balers have a double acting check valve mounted on the tensioner system to maintain the pressure rather than rely on the tractor control valve. If yours has a check valve that also may have failed.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
