Changing to a 6 Volt starter motor will have no effect whatsoever on the ignition system. Moreover, the 6 Volt starter will not be harmed by running on 12 volts.
Always check the obvious first:
1). Is it getting fuel?
2). Is there water in the fuel?
3). Is there spark at the spark plug?
4). Is ignition switch operating? (check for short circuit)
5). Are the coil connections tight (check wire into back of terminal!)
6). Is the breaker point and spark plug gaps correct?
7). Is the ignition timing correct? Check the distributor is rotating as it should.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
