First make sure your aux hyd valves are working freely and centered and the double single action adjustments are not turned beyond their roll pin stop, or broken roll pin possibly. If they are good, then you most likely have a plugged orfice and screen inside the regulator valve assembly. It is cover with four bolts, has heavy spring under it so take out two bolts and install two longer ones for safety, remove cover, orfice has screwdriver slotted head. Remove and clean if it is not destroyed. Cut bottom off of screen and after cleaning, just roll it back up a bit. If it is a .024 orfice I would drill it to .031 like newer ones are. Also pull regulator piston and replace o-ring and inspect parts. You will need new gasket for cover. A new orfice will cost you (maybe $40 bucks).
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
