Re: M Block repair
Posted by Janicholson on February 14, 2011 at 06:24:41 from (199.17.6.194):
In Reply to: M Block repair posted by FarmerBrawn on February 14, 2011 at 06:03:29:
A cut is easy to repair. If it is easily accessed and not too deep, a braze job on it would be pretty easy and certain fix. If it is a crack, then it will be more difficult.
The sleeve ring at the top of the cylinder bore is usually wide enough to prevent water leaks across the gasket into the cylinder. If the sleeve is cracked, just replace it. Fixing a sleeve is like taking a 20 dolar watch in for circuit repair. A cut in the casting of the block into a water passage is not good, but if not drastic, will not prevent the reliable operation of the engine. If the crack is drastic when the sleeve is pulled, the cylinder can still be saved with a repair (thick) sleeve installed into a bored out block, then re-machined for the liner sleeve ring. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
