Posted by AL Farmall Boy on February 01, 2011 at 09:20:17 from (216.226.179.180):
Hey fellas. I am having trouble with the headlights on one of my Super A's. I just re-wired the tractor and ran the headlight wiring. The test light shows the headlight connections to be "hot" when the switch is turned on (check). I hook the terminal up to the light (with new 12 volt bulb), and I get nothing. FYI, I have the glass lens off for testing. I use the test light to check power, and find that when I touch the reflector (bulb housing), it lights up the test light showing it is "hot". When I touch ANYWHERE on the reflector, the test light lights up. ALSO...when I touch the light post that the light is bolted to on the tractor, it shows that to be "hot" as well. Anything else I touch past the light post does not light up the test light.
I was assuming I had a bad ground, so I sanded down the top and bottom of the light post where it bolts to the light, and I am still having the same problem. ITS DRIVING ME NUTS!! THANKS.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
