Posted by Wardner on January 24, 2011 at 08:46:16 from (209.86.226.12):
In Reply to: hey Wardner posted by Nebraska Cowman on January 22, 2011 at 11:23:56:
Well, to start, you want to use a pressure vessel as opposed to syphon fed gravity system. 100 cfm may seem like alot, but I used 750 cfm and could run two days without refilling. I bought 5/8" nozzles and wore them out to 3/4" plus. Tank held seven tons of elevated silo-stored sand. I was routinely blasting and painting 10,000 sqft per day on new steel.
You will probably be able to run a 1/4" nozzle. Various improvements would include a pop-up valve to close the filling port on top, deadman controls for starting, stopping, and clearing blockages, and perhaps a moisture separator. Try running without the separator to see if you need it.
You should definitely budget for an air-fed helmet with a separate air source. A small vane pump would be adequate. Use ear plugs too.
I have seen plans on the internet for home-made blasters. You should look over several designs and compare them to factory built units. Alot depends on what your budget is and what you can pull out of your (or other's) junk pile. I used propane tanks. Working pressure is 250 lb and they are always clean inside. I used the one above for 25 years without incident.
A hobbiest's needs are different from a high production professional. I used to spend $500 on my sand valves. They were made by Schmidt and were lined with carbide. You could probably get by with a hand operated ball valve from Home Depot. My air valves were also expensive. I used quarter turn air-operated 2" ball valves. I stayed away from the diaphram junk.
Don't overlook Craigslist and eBay. Don't pay much for a home-made blaster.
This post was edited by Wardner at 08:51:22 01/24/11.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
