If I recall correctly you just got this tractor from a scrap yard. Did the hydraulics work before you started to change oil and filter? Does the PTO start up? If not the problem may be the PTO input shaft splines in the clutch pressure plate. The PTO drive shaft also drives both hydraulic pumps. Usually they will make some noise but that goes away if it has been run long enough with the splines worn out. Another possibility is the rivets sheared off the back of the pressure plate cover. When that happens there usually is no noise. You can inspect this by removing the cover under the clutch and looking up between the clutch release levers on the pressure plate.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
