Posted by Troy Schubert on January 03, 2011 at 13:48:32 from (63.166.241.80):
The right side roller bearing cup in the differential has some major divots/damage. I've visually inspected the other bearings in the differential and they appear OK. I've convinced myself that I need to replace the bearing cup at a minimum.
Looking for any advice:
1/ should I replace the right side roller bearing AND the cup even though the bearing looks OK?
2/ Only place I can find to order the bearing cup is www.messicks.com. P/N 86500721 for $63.81. Any other ideas where I can order this Timken bearing? The original Timken number for the whole bearing is 3044002R91 and it cross references to a 482/472. All my searching has not produced any US distributor where I can order it.
Best I can tell from the Timken failure analysis pics is that the bearing was exposed to water and corroded. It makes sense because I do have a leak between the differential cage and diff housing, but doesn't make sense because the other bearings appear OK.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
