For what it's worth, when I recored my F-20, I used 5/6" copper heavy wall tubing and soldered it in. You have to clean the the line and tank REALLY well before you start.
works fine, and doesn't leak.
I did have to use the acetylene welding tip to get enough heat though. you need to be real careful, and heat the tubing......too much concentrated heat is no good for the cast. I tinned it before I put it in, then heated the brake like, and pulled the solder in. I did the tank side first, then turned it over and did the rad side last, to let the solder work down and around.
It would be interesting to use JB Weld for this job. I have had excellent success with JB weld for repairing the oil cups on the air cleaner and similar sheet steel parts.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
