Posted by Tom 43 on December 30, 2010 at 11:35:06 from (99.117.18.191):
In Reply to: Coil 6v or 12v?? posted by Mr. Mayor on December 30, 2010 at 08:26:57:
Coils are not just one size fits all! Most coils will work on any application at least for a short time. During the days of 12 volt, point type, Kettering ignition(roughly 1955 through 1974 with many exceptions) the automotive industry used what would best be described as a 6 volt coil with external ballast resistor in their 12 volt systems. However, these coils are different in respect to manufacturer. Ford, GM, and Chrysler all had different primary resistances in their coils, along with brand specific ballast resistors that were built to match specific coils. There were also matching condensors with various micro-farad capacities to match a specific ignition system. For optimum performance coupled with long life, the correct parts MUST be used.
Deere used a six volt coil on the B's six volt system. The A and the 60 used an unballasted 12 volt coil. The 620 and 630 use a ballasted six volt coil with a resistor bypass for easier starting. Putting a coil from an A on a 620 will cause weak spark and poor performance if at all. Putting a coil from a 620 on an A will work great for a little while until the points burn up because of twice the specified current flow.
John Deere combines such as the 55 and 95 use a 12 volt unballasted coil like the A and 60. I presume since combines usually run in temperate weather, Deere felt they didn't need the extra expense of a bypass system.
I have experienced countless ignition problems caused by people mismatching coils! The combine or tractor stops and a coil off a junk car, pickup, or tractor sitting in a fence row is substituted. As jdemaris points out, 90% of coils are of the 6 volt type with external ballast. However, when you put one of these coils on an A, 60, or 95 combine it will work just fine for a couple of days and then new points are needed. It is very hard to convince the customer he needs a new coil when it works good for awhile. There is nothing wrong with the coil, it is just using the wrong part for the job.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
