Posted by sgtbull on December 22, 2010 at 21:39:40 from (163.191.228.254):
In Reply to: 49 cub seal posted by ericlb on December 22, 2010 at 11:48:07:
Chances ar good you have an old leather seal, and it needs replaced. Even in the oil level was high, if the seal was good, the leakage should not be so much as to affect your brakes. The quill that holds the seal can be removed without any consequences, but there are likely shims behind it, and a large rubber oring that seals the quill in the bore. Remove the three bolts and carefully begin working the quill out, starting with a stiff putty knife, andgraduating up in size to smaller pry bars, used carefully so as to not damage the shims or break the quill. Once you have it out, any local bearing/seal supplier can match it easily.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
