Posted by rustyfarmall on December 18, 2010 at 12:54:59 from (209.152.78.140):
In Reply to: light switch posted by Blackstack on December 18, 2010 at 11:07:50:
The 4 position switch was used with the cut-out relay which did not automatically regulate how much charge was being put into the battery, so if you were using the lights, the high charge position was used, and if using the tractor WITHOUT the lights, the low charge position was selected to prevent overcharging the battery and boiling it dry. I sometimes use the high charge position on my 1940 H if I will be running the tractor for only a short time, because it will more quickly replace what is lost in the battery from just starting, but the low charge position is always used when using the tractor for an extended period. The ampmeter is a good indicator of which setting to use.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
