to add to charlies post, you need to turn the drive coupling so one half of it points vertical. its basically a real thick flat washer with two raised areas, like a cross. also when in there replace the seal on the drive dog that comes out of the trans. check the trans input shaft seal too, if its leaking, change it now. when you separate the pump from the resevoir, you can slide a small bar to lock the pump gears to spin off the pump drive to change the seal. when putting the pump back on the resevoir, be sure to get the little fork hooked up to the bracket that actuates the pump from the control rod. if you get it hooked, the control rod wont work and you will need to drop the belly pump again.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
