Posted by Idaho Ron on December 06, 2010 at 17:53:30 from (208.98.157.18):
I wrote about my super c a little while ago not running. It was running and idled good but when I let out the clutch it would bog down and run rough. Or if I used the hydraulics it would bog down. It first started after the tractor got warm it would start bogging down
I cleaned the gas bowl and screen. I cleaned the screen in the carb they were all ok. I put it all together and it won’t start.
I thought it might be the carb so I took it off and had it rebuilt. I put it back on and it still won’t start. I gave it a shot of starter fluid and still no pop. So I am now thinking that it is electrical, to be exact I am thinking it is the coil. SO I put a tester on the back of the coil. I got power to the pin on the motor side but nothing on the pin close to me. If the key is on should both of these have power? Also I wanted to look into the points and I can’t get the distributor rotor off the shaft. I have tried everything but breaking it off. It is stuck. Is there a trick to getting it off? Thanks Ron
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
