Posted by Owen Aaland on December 02, 2010 at 14:01:44 from (65.165.246.162):
In Reply to: IH 460 issues posted by Janicholson on December 02, 2010 at 09:16:50:
What style of PTO do you have? Early tractors had a planetary type. That unit has a small oval cover on top and the engagement lever will latch in both the engaged and brake position. The later tractors had the over center clutch style where the handle will latch only in the brake position.
The later, over center type, is more likely to see this problem. If the bolt that clamps the lever to shaft going into the PTO unit is not tight enough the woodruff key in the shaft can shear off and you will not be able to shift it. If the linkage moves going into the unit itself you may have mechanical problems that will need disassembly to repair.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
