You can turn the rims around to get more clearance but the tractor will suffer for it. It causes harder steering and can lead to broken spindles.
If you follow the center line of the spindle down to the ground you will find that it meets the ground about the middle of where the tire contacts the ground. That allows the wheel to pivot on that spot when the wheels are turned. If you reverse the rims the center line of the spindle will not be in the center of the tire. When the wheels are turned they can no longer just pivot but must also roll. This increases the effort needed to steer.
Also by moving the wheels out away from the center line it changes the forces on the wheel bearings. As originally designed most of the load is carried on the larger inside bearing. With the wheel moved out the load moves more to the smaller, outside bearing. This makes the horizontal part of the spindle act like a lever and greatly increases the forces on the angle of the spindle. This can lead to spindles breaking at the inner end of the large bearing.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
