Posted by Zachary Hoyt on November 17, 2010 at 17:23:20 from (184.12.75.47):
In Reply to: H steering posted by bmagee on November 17, 2010 at 17:14:53:
Best thing to do in my opinion is first to narrow down where the slack is, first turn the wheel and look at the U joint, then if that is tight look at where the shaft goes into the gearbox, etc. My H had a lot of slop when I got it and what I found was that the worm gear inside the gear housing was moving back and forth. I took the large pipe cap off the front of the gearbox and found a large washer that fit between the end of the worm gear and the inside of the cap. I filled the box with grease, put the washer on and screwed the cap back on. It now has virtually no play, although it requires slightly more effort to turn the steering wheel. The first time I put the pipe cap on I didn't get it tight enough and it fell of when I was pulling a load of gravel. I knew when I completely lost steering all of a sudden. After that I tightened it with the 24" crescent wrench and it has stayed on since. Zach
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
