Posted by twomanyprojects on November 07, 2010 at 21:33:17 from (68.6.103.30):
We have an 806 with a front end loader. Because we use three separate hydraulic controls for various functions on the loader, my brother rigged a triple set of valves on the right fender which are supplied from the right auxiliary hydraulic ports. To use this, we put a block of wood under the outer control valve lever (located next to the seat, right side) to lock it in the "up" position so the right auxiliary hydraulic ports are always pumping fluid. This has worked for years, but now we have a problem.
Some of the time the loader will lift very slowly, or not at all until you rev the engine up to fairly high speed. Even then it lifts very slowly. Seems as if we are leaking fluid through or around some check valve or unloader valve. If you put the auxiliary valve in the "down" position (thereby driving everything in reverse) it will raise the bucket at the normal rate in both of "up" or "down" position on our triple valve.
I thought it might be the control valve itself that runs the auxiliary port, but when I switched the lines to the rear hydraulic ports, (which are controlled by the inner control valve handle) we get the same results.
I have GSS-1344 manual and a parts manual, which describes the hydraulic control system, but am not sure exactly which of the check valves or unloader valves would be the cause, nor exactly where to look (other than under the seat.)
Any suggestions on this problem would be greatly appreciated
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
