Posted by M Diesel on November 04, 2010 at 11:14:53 from (12.24.61.12):
In Reply to: 650 IH posted by plow hand on November 03, 2010 at 19:44:15:
I'll add in that the butterflies in the intake manifold are a major culprit for not starting on gas. Their job is to divert air from the main passages into the carb passages. They are not forced closed. The linkage just pushes the shaft past center and then a spring on the shaft (in the end of the manifold) pulls an arm over center and finishes the job. If the shaft develops a bit of a drag it won't snap closed. You can reach in behind the manifold and work the shaft manually to a certain degree. The feel will tell you if it isn't right.
Another FYI, the butterfly shaft kills the ignition when in diesel. There is a switch at the front end, presuming it is hooked up.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
