Posted by Harold Hubbard on October 20, 2010 at 15:56:22 from (205.209.16.24):
Yesterday my C started misfiring and stumbling every time I let the clutch out, but it would smooth out and run right after it got moving. I was clipping a pasture with the sickle bar, and managed to finish up without it getting any worse.
So, this morning I dug into the distributor, expecting to find some moisture and maybe have to reset the points. Got it open and it was full of powdered rust, so I pulled it out for a complete disassembly and cleaning. I got it all clean, actually plugged the shaft bore and bead blasted the housing, and started re-assembling it. I pulled a new set of Genuine IH, made in USA points off the shelf, installed and gapped them, re-installed the distributor, and tried to dead time it. GAAA!!! NO CONTINUITY THROUGH THE NEW POINTS. Did the clean rag, clean paper thing, nothing, rubbed the points vigorously together, zip, cursed a lot. Just what I really want to do, file a brand new set of points to make them work, no. Finally gritted my teeth and hit them with a Scotch-brite disk on my die grinder, took two hits of that before I got a good contact.
Ten minute job wound up taking two hours, not all the fault of the points, they were just a bit of added aggravation when I thought was nearly finished. I guess I should just get the TSC, made in Mexico, points next time, at least I will be expecting them to screw up. The last pair of them I had snapped the spring, and the tractor stopped right there.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
