Posted by Janicholson on September 28, 2010 at 19:08:34 from (67.72.98.45):
In Reply to: Backlash, again posted by CNKS on September 28, 2010 at 18:54:38:
Putting it at .007 will be a good compromise. THey will make noise no matter what if they are used gears, and run with the lash close and the pinion depth good. The tooth pattern is more important on used gears than the lash, but with poor visibility the only choice is to be as close as possible. If the gears are 3" and the pinion is ~1.750 in radius at the pinion, an approximation is to double the lash when measuring at the gear. A good pattern is found by putting prussian blue on the gear teeth (pinion or ring) on the driven side, Put a weight or resistance on the ring gear and turn the pinion till the same tooth becomes visible again. The pattern should be centered on the face of the tooth, and blend outward to the edges from there. There are good examples on Google images ring gear wipe patterns. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
