Posted by Owen Aaland on September 28, 2010 at 15:35:36 from (65.174.247.47):
In Reply to: 706 Hydraulic help posted by glennster on September 28, 2010 at 05:15:56:
Do you hear any change in load on the engine when you try to lift the mower? If you are using a cylinder and you hear a change in load, check the couplers. If using a pioneer coupler with a ball connected with an IH coupler with a point, they can cause problems when they get worn. The point in the IH coupler slides to the side of the ball allowing the ball to close and shut off the oil flow.
If you are using the hitch it is possible the problem is with the unloading valve. If it lifts when you hold one of the auxiliary on pressure then the problem is with the unloading valve.
If you are using a hydraulic cylinder, and you hear no change in hydraulic load, see it it will move the cylinder just by itself. If you have no flow then, the most likely cause is the relief valve stuck open. It is a pilot operated valve so even if it looks good and does close, if the small spring breaks in the pilot part of the valve it will not allow any pressure to build up. The best way to check it is to swap it with a known good valve.
Other causes may be a blown gasket/O-ring or a pump failure.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
