It is a common problem on older tractors, trucks, and even cars. The quick remedy on a tractor is to shut off the switch, put the tractor in gear, and rock the tractor by pushing against the rear tire. Usually you will hear a "click" from the starter, and then you are good to go. Sometimes that trick does not work, so then you get out your 3/4" wrench, loosen the bolts that hold the starter on enough so you can pull the starter back, and then you will hear the click. Tighten the bolts again and it's done. Eventually, you WILL need to replace the drive on the starter, and quite possibly split the tractor and replace the toothed ring gear on the flywheel. The ring gear is not expensive, but the work involved in getting to it can be, unless you do it yourself.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
