Posted by Owen Aaland on September 24, 2010 at 15:54:33 from (207.13.114.193):
In Reply to: 706G dump valve adj. posted by Janicholson on September 23, 2010 at 10:11:26:
You have the classic problems caused by loss of flow/pressure from the MCV pump.
Unless the tractor stops completely and not just act like a slipping clutch, the problem you are having is not caused by the TA. Not having the problem when the TA is in the low side will confirm this. If that is the case a new TA will act the same.
When the pump gets weak it can no longer provide enough flow at higher steering pressures to maintain 3 GPM to the control circuit for brakes and TA. When the flow drops enough so that the pressure cannot be maintained in the direct drive clutch of the TA, the clutch will slip and the TA will pull on the low side clutch. This is the loss of speed that you are noticing.
Continuing to use the tractor will cause excessive wear in the direct drive clutch pack while it is slipping. More critical is something that you do not notice. Whenever the MCV pump cannot provide flow in excess of 3GPM there is no oil flow through the oil cooler. The oil returning from the oil cooler is used to lubricate the range transmission,bull pinion bearings, and the ring gear and pinion.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
