1) Think of the battery as a big capacaitor or an electron bank i.e. a BUFFER OR SHOCK ABSORBER so a standard correct wired points ignition (or an elec ignition) shouldnt be the cause of alternator damage.
2) If an alternator lacks a voltage reference (sense) it may be damaged as it may over work and draw excess current.
3) On Delco 10 SI alternators I recommend the use of a 10 ohm current limiting safey resistor in the excitation circuit VERSUS A DIODE like most use. Also an incandescent idiot light is great cause it serves two purposes, its a current limiter PLUS it works as a non charge indicator (Idiot Light). Some even go so far as an idiot light in paralell with a resistor as a safety backup in case the idiot light opens. HOWEVER I dont see the fact it lacked one altogether as the cause of failure, Ive seen them with no diode or resistor that lasted n lasted n still working
4) Resistor suppressor plug wires are to reduce RFI interference and I see no need for them in stock points ignition systems, especially if its a magneto where Id use wire core wires,. HOWEVER in some high energy electronic ignition systems they actually prefer some degree of resistance and/or inductance in the HV secondary and do in fact recommend use of supressor wires.
5) If the coil is rated for 12 volt use (versus 6) then no external series ballast is needed as in the case where the old 6 volt coil is used after a 12 volt conversion
CAUTION if youre using points, you may wanna check the primary resistance on that TFI coil you mentioned as some (not all) coils used on high energy or elec ignitions may draw much more then 4 amps and if so your points will burn prematurely!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
