CNKS is correct if it is a Live pump on the engine in front of the distributor. If it is a belly pump, it is in the middle of the tractor and accessed from the bottom. If belly Liftall pump, the seal in question is a lip type seal and easily changed It is necessary to drop the drive shaft to the pump (sheet metal cover) cotter pins, and remove shaft. Drop the pump with care after removing the elbows and control lever and cap. It is heavy and awkward. A floor jack and two people, or threaded rod with nuts to lower it are good options. When lowered, the drive flange needs to be removed. it will be tight. Remove the pump from the reservoir casting. Stick a brass or copper wedge into the gears through the intake port. Turn the slotted drive flange CCW to loosen (normal threads). The seal is then easy to replace. A duplicate should be able to be found at NAPA or Motion Industries etc. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
