Posted by pete 23 on August 25, 2010 at 10:47:06 from (173.87.8.216):
In Reply to: 240 utility hyd issues posted by Vally Farm on August 25, 2010 at 09:06:03:
I think you have a plugged orfice screen in the regulator valve assembly. Valve block with four bolts on top. Orfice screws in with screwdriver slotted head. Orfice supplies regulator piston fluid to depress ball unloading valve below piston for low pressure standby. If screen is not broken you can cut end off to clean up and just roll it up again and reuse. Note, strong spring under cover, I use a couple of longer bolts in corners to assemble. Also, 0-ring on the regulator piston will need replacing. Far as adding another valve, should be no problem to add, just finding one from salvaged tractor, one from several different model tractors should fit.
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
