The TA in a 656 works like a 2-speed Powerglide automatic transmission, except that it's shifted manually by a lever.
In an oversimplified nutshell:
The TA unit sits in between the engine and the transmission so it has an effect on all gears.
There is a clutch and a planetary gearbox inside the 656's TA. The TA lever engages and disengages the clutch.
When the clutch is engaged (TA lever ahead), it locks the planetary gearbox and spins it as a unit. The gearbox acts as a solid shaft and gives you DIRECT drive to the transmission.
Pull the TA lever back, and the clutch disengages. Now the planetary gearbox goes to work and reduces the RPMs from the engine to the transmission. This gives reduced speed, but multiplies the torque from the engine.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
