Posted by bkpigs on August 19, 2010 at 19:57:53 from (75.132.223.199):
First off, thanks everyone for the previous ideas and pointers. This is my first mag. tractor so it is a bit of a steep learning curve compared to the battery ignition.
I still am having no luck. I re-gapped the points to .013, no spark. Put the old points back in, no spark.
My confusion really builds when I started doing some contenuity testing.
I get connection between the grounding bolt on the side of the mag. and the frame of the motor. I disconnected the switch from the grounding wire to eliminate the posibility of a faulty switch during this test. Is this normal? I would think not but if the mag. is producing a direction of flow and the windings in the mag are back feeding then it would be, right?
I also get contenuity between the spring side of the points and the solid side of the points. I even removed the spring side completely from the distributor and left it only hanging by the wire. Still got contenuity; that can't be right, can it?
As I stated before in the previous post I did NOTHING to the mag. itself. I just changed the points and cleaned the rotor drive gears (which I got back into the right time).
I have been having my dad hold the wire that comes from the top of the mag. next to a spark plug while I crank and there is no spark. Even if it was out of time (the rotor and such) I should be getting a spark.
Could it be the million to one chance that when I changed the points something inside the mag decided to call it quits? If it did I should have bought a loto ticket that night.
Thanks for all of your contributions. Hopefully I will be able to get the tractor going by Sat. morning to get it to my old hometown's German festival.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
