Posted by Marty from MN on August 18, 2010 at 18:17:35 from (75.73.148.235):
I acquired a '51 M from my FIL that had been sitting for around 5 years.
Got it going again and now that it is moving, I found that the transmission is whinning. I figured I had better change the trans fluid. Drained out 4 to 5 gallons of water and not much oil. Filled it back up with new fluid.
That helped some but it still whines quite a bit. I also found that it pops out of 4th under a load (going up a long hill). I haven't tried 5th. All gears sound about the same, with the pitch going up for the higher gears. The whine goes away when not under load (downhill). There is no noise when in neutral with the clutch out. Also no noise when coasting.
Are the gears and bearings just rusty? Is a bearing going out? Should I keep running it to see if it clears up or will that cause more damage? Why is it popping out of 4th?
This post was edited by Marty from MN at 18:18:34 08/18/10.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
