Posted by Owen Aaland on August 07, 2010 at 20:20:51 from (65.165.246.191):
In Reply to: 210 IH Swather Coil posted by LonM on August 07, 2010 at 13:10:22:
I think your problem is the fuel vaporizing in the fuel line from the tank to the pump. You could try fabricating a heat shield between the engine and the fuel tank. A piece of sheet metal between the tank and engine can reduce the amount of heat transfer quite a bit. Using an electric fuel pump at the tank to keep the fuel under pressure will also help.
As far as the ignition system, if you have a 12 volt system with no visible resistor, it is quite possible that the necessary resistance is built into the wire between the ignition switch and the starter solenoid. If you have two wires on the I terminal on the solenoid and only one wire at the coil, you have the resistance wire and need to use a six volt coil. Systems that have one wire on the I terminal on the solenoid will have two wires where they attach to the coil. One will come from the starter solenoid and the other from the ignition switch after running through a resistor block.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
