Posted by Owen Aaland on August 02, 2010 at 18:54:53 from (65.165.246.191):
In Reply to: 856 oil leak posted by mkirsch on August 02, 2010 at 18:33:34:
I think you are referring to the transmission brake, not the parking brake. The parking brake is located under the range transmission cover, just in front of the seat.
There is an O-ring on the shaft that operates the transmission brake. To replace it you need to drain the transmission oil and remove the bottom cover. There is a clip that holds the transmission brake lever in place and a short pin through the cover into the shaft that holds the shaft in the cover. There is also a woodruff key between the shaft and the brake pad lever. Once the pin, clip and woodruff key are removed the shaft can be withdraw from the cover and the O-ring replaced.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
