Pull off a plug wire and hold it away from the sparkplug about 1/4". Then have a helper to make an attempt to start the engine. If there's no fire rub the points with a piece of 320 wet or dry then see if the engine will start. If it starts you've found the problem. If there's still no fire to the plug you need to use a volt meter to see if you have battery voltage at your coil with the points open. You need the ignition switch in the on position too. Look at those points if they're pitted replace them and the condenser.
Run a separate wire from your battery to your coil then see if the engine will start. Hal
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
