Re: Super C starting issue
Posted by challenger on July 27, 2010 at 19:12:15 from (96.255.209.165):
In Reply to: Super C starting issue posted by Farmall Freak on July 27, 2010 at 18:28:26:
If you have spark coming from the coil, your distributor timing must be off. Find the top dead center on the compression stroke on number one cylinder. You do this by removing the spark plug, put your big thumb over the hole, crank the engine over slowly, and feel for the compression stroke (air being forced out). Then carefully line the TDC notch on the front pulley with the timing pin. Take your distributor cap off and make sure the rotor is lined up with the internal post for number one cylinder. If it is not, try to get it there by loosening the distributor mounting bolts and rotate the distributor. If you need more movement to accomplish this, you will have to pull the distributor out and move the drive gear one or two cogs as necessary. This should get you close enough to at least get it started. Also make sure the advance mechanism in the distributor body moves freely and is not hung up.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership, ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
