Posted by D Slater on July 17, 2010 at 17:53:07 from (72.65.148.95):
In Reply to: Starter issue posted by SCOTT300IOWA on July 17, 2010 at 15:42:36:
When the switch is turned to the start position check to be sure power is getting to the small wire terminal at the selonoid. If so its probably a bad selonoid. If not check the terminal at the switch that energizes the selonoid. If no power there its a bad switch. If power there its a problem with the wire from ignition switch to the selonoid. Or try a jumper wire from the battery cable side of the seloniod to the small terminal. (Don't know if thats how you're jumping it or across the 2 big terminals) If it turns the problem is the ignition switch or wireing. Not uncommon for those key switches to go bad.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
