Posted by jeffalex2 on July 17, 2010 at 03:53:31 from (71.246.72.180):
In Reply to: H battery discharging posted by Drewbee90 on July 16, 2010 at 17:42:50:
Need a little more info...are you running battery or magneto ignition? 6volt or 12volt? Generator or alternator? If you are running factory 6volt set up with a magneto, the most likely culprit is the regulator is defective or wired wrong. Does the ammeter show a discharge when the tractor is shut off?
Also, don't rule out defective battery. I racked my brain for 2 weeks over a bad Napa battery on my Super M. Take the battery out of the tractor and make sure it holds a charge by itself. While disconnecting the battery, take off the negative terminal 1st and try and see if there is a small spark while you remove the terminal, if so, then you have a short in the tractor somewhere.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
