Posted by M Diesel on July 14, 2010 at 10:36:55 from (12.24.61.12):
In Reply to: Leaking MD fuel line posted by Janicholson on July 14, 2010 at 07:36:12:
Janicholson said: (quoted from post at 07:36:12 07/14/10) Clean it well with brake clean spray, then use good light and watch where it begins leaking. A careful analysis might find a crack that will not be repairable, but it could be a flange or seat that has a scratch that can be polished out. A good diesel shop (or someone willing to look at the part using possible teflon lined stainless steel brake line as a substitute) might work. Salvage yards are the only other alternative. Jim
Really does sounds like a crack. There is no pressure on that fitting. I will say the filter isn't especially needed either. It is just there as a precaution to stop crud introduced into the line from getting into the primary pump.
Salvage yards are a good option, like steelwheelranch.
The entire unit can be replaced with standard plumbing if you want. I have used a standard hose barb and rubber line at that point. I can't remember if it is 3/8 or 5/16.
It is possible the leak may be sealed with fuel lube. You need to be careful with that stuff around injection pumps, it should not be gooped on.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
