Posted by Janicholson on July 13, 2010 at 10:50:21 from (199.17.6.23):
In Reply to: NO spark posted by b4favre on July 13, 2010 at 08:35:25:
With the wire to the distributor removed from the distributor, see if there is voltage on the wire with the ignition on. If not, see if there is voltage on the other side of the coil. if not the ignition is not getting power (either from the switch, or through the amp meter to the switch, or to the amp meter from the starter switch. If power is there, at the wire to the dist., put the coil wire about 1/8" away from the block and then brush the wire against bare metal (you are acting like points) it should spark the gap at the coil wire. if it does not, the coil is probably bad. If it does, the points are not working to make and break the circuit. Gap is .020" when they are open and the rubbing block is on the high point of the distributor cam. Jim
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
