Your tractor has two mostly separated hydraulic systems. It starts with a common source from the pickup tube through the filter. After the filter the suction side of the pumps are separate. Filling an extra five to eight gallons of fluid will cover any areas that may be leaking on the suction side.
There are two areas where the 86 series tractors differ from the earlier ones. First is the long dipstick tube in the back to check the oil. If the tube is bent down inside the tractor the actual fluid level may be much different than indicated on the stick.
The other area is the supercharge line and it again connects the suction side of the pumps. It is designed to reduce the amount of oil flow through the filter. Oil from the rear pump is routed up through the hitch and to the auxiliary valves. If neither the hitch or the auxiliary valves demand any oil, the return flow is routed to the suction side of the front pump at the bottom of the MCV assembly. If there is demand for oil, the flow to the supercharge is cut off so no unfiltered oil returning from the auxiliary valves is allowed to enter the suction side.
The reason I think your problem is with the supercharge line is because you said it came on suddenly and affects both hydraulic systems. A crack in the line can allow air to enter without leaking oil out because you have the demand for oil from both pumps but are supplying oil only from the rear pump. There should never be pressure in the line, only suction.
A crack at the end of the line under the fitting may allow a metered amount of air to enter. Since the amount of suction on the line will not vary significantly from low idle to high idle the volume of air entering will remain nearly constant. The amount of oil demanded by the pumps will nearly quadruple from low idle to high idle. As a result the percentage of air in the oil entering the pumps will be much lower at high idle and account for the better performance at higher speeds.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
