There are an assortment of issues here: It was not 12v from the factory, so it isn't "stock" but that is OK. One polarizes the generator by jumping Bat to Gen on the regulator. (the VR is not polarized by jumping it might have polarity if it has solid state parts in it, and some new VRs do, but it is usually able to charge either polarity. The charge rate is a little high at 16v but two other things are important. The use of a DMM is frequently impossible on these unless you pay for a Fluke meter or equal. THe sample rate of the meter grabs information on a noisy (irregular to beat the band) voltage source, and will not average the spikes or valleys it encounters. An analog meter with a needle is usually the much more accurate answer. A bad Vr would cause a bat to drain, but it would also heat up wires and heat the generator, if it did. Thus the drain is either a light that is on, the ignition switch is not turning off all the way, or (most likely) the battery has a bad cell in it. I would check the battery first. It is easy, charge it up with one terminal disconnected from the tractor, then let it sit for a few days and measure the voltage. The DMM will work here! If it is less than 12v, and will not start the tractor,, it is bad. I think the charging system may be OK. Good luck, Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
