Yes, because the barrel that couples to the crank is usually seized. Then there is the stamped spring retainer which is likely to be seized on the barrel as well as the 1/2" dia pin.
If everything has been gobbed up with grease for the past sixty years, it's not a big deal. Otherwise, you will probably have to remove the bolster. Bear in mind that the job requires one to work on his back with his hands inside the bolster casting. Do you have any 5-6 year olds in the neighborhood who like tractors.
Think about compressing the spring with several tie-wraps.
I did this partial disassembly to slide the barrel back far enough to install a 2 groove pulley on the crankshaft. This was an old bolster I had to see if it could be done before attempting the same job on my 400.
As I look at these pictures, I am not even sure that the barrel will come out if the bolster is still attached to the frame rails. I have only removed barrels on separated bolsters. Perhaps you don't need to replace the barrel. You haven't indicated what the problem is.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
