The front gears only need to be timed if you are using a magneto. Even then it is possible to install it from the rear and get it timed correctly.
For a distributor just install the drive and then make the timing adjustment when you install the distributor into the adapter housing.
For a magneto turn the engine to TDC on number 1 compression stroke. Use a mirror to locate the timing mark on the front of the camshaft gear. Mark the tooth (or two teeth if the mark is between teeth) so you can see if from the back side of the gear. Locate the mark on the driven gear and match it to the correct teeth on the camshaft as you install it.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
