Posted by gatorhide on July 05, 2010 at 11:28:03 from (24.155.13.131):
Well, the M still won't run.
I tried to start it and when I let off on the start button, it continued to turn over. I had to disconnect the + cable in order for it to stop turning over.
Is the new push start button malfunctioning ? Or is it the new on/off switch malfunctioning ? Or both ?
I took the distributor out and examined the stud bolt and the insulation on both inside and outside of distributor and did not detect anything there appearing wrong. I also made sure the points are set @ .020
When I tried starting the M again, it would backfire and this would be incorrect timing, but I couldn't get it to start so I couldn't set the timing.
I'd forgot to make a mark where the distributor was set at before removal.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
