3 Amps rating should suffice for the alternators required initial excitation current and 100 volts withstand rating is plenty so YES it should work okay, rememember its polarity sensitive so for Neg ground its Cathode band should be towards the alternator.
NOTE instead of a diode one can use EITHER a 10 ohm 10 watt resistor (no worry about polarity) as it also prevents the run on problem PLUS provides some degree of current limiting safety ORRRRRRRRRRR instead one can use a small incandescent idiot light charge indicator to be on when shes NOT charging but off when she is ORRRRRRRRRRRRR use the idiot light in paralell with the current limiting safety resistor so she can still charge should the idiot light burn out.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
